Brachistochrone homework problem
The discussion revolves around the Brachistochrone problem, specifically focusing on the parametric equations of a cycloid and their relationship to a differential equation. Participants are attempting to derive a relationship between the parameters involved and interpret constants within the context of the cycloid.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants are discussing how to substitute parametric equations into a differential equation and are exploring the implications of their findings. There are questions about isolating variables and interpreting constants in the context of the problem.
The discussion is active, with participants providing guidance on substitution methods and questioning each other's work. Some participants express confusion about the steps taken and the implications of their results, indicating a collaborative effort to clarify the problem.
Participants are working under the constraints of homework rules, which may limit the extent of guidance provided. There is an emphasis on showing work and understanding the relationships between variables rather than simply arriving at a solution.
twalker40
1. use the parametric equations of a cycloid ( x=a(t-sint), and y=a(1-cost) ) to show that y=y(x) is the solution of the differential equation for any parameter a. Find the relationship between the radius a in the parametric equations and the constant C in y(1+y`2)=C.
2. Solve the equation y(1+y`2)=C with the initial condition y(0)=0. Express rather x as the function of y. what is the interpretation of the constant C in terms of a cycloid.
I need help starting the first question. In #2, I am stuck at 1+y`2= C/y. i know your not supposed to subtract 1 to either side, so how am i supposed to isolate y` by itself?
To start the first part just substitute the forms you are given for x and y into the equation. y'=dy/dx=(dy/dt)/(dx/dt).
if i sub those in, i get 1-cost=1-cos(t-sint). I am stuck here :(
As for questions number 2, i got to x=[tex]\int[/tex][tex]\frac{2cu^{2}}{(1+u^{2})^{2}}du[/tex]. where do i go from here?
(with u^2 = y/(c-y) )
For part 1), no, you don't get that. Show your work. And I'm not dealing with the second part until you get the first.
ok, I am a bit confused here. Do u mean sub those parametric equations into y=y(x) or y(1+y`2)=C?
if its y=y(x), that's how i got 1-cost=1-cost(t-sint).
If its the latter, then dy/dx=sint/(1-cost).
then i plug it into the equation to get 1-cost(1+([tex]\frac{sint}{1-cost}[/tex])2)=C
-> (1-cost)(1+[tex]\frac{sin^{2}t}{(1-cost)^{2}}[/tex]) = C
-> multiplied out i get (1-cost) +[tex]\frac{sin^{2}t}{1-cost}[/tex] = C
-> [tex]\frac{1-2cost+cos^{2}t+sin^{2}t}{1-cost}[/tex] = C
-> [tex]\frac{2(1-cost)}{1-cost}[/tex] = C
-> 2 = C
how does C = 2 answer "show that y=y(x) is the solution of the differential equation for any parameter a"?
You missed an 'a'. I get 2a=C. That answers 1. For 2 if you have the substitution correct, then it looks like a u=tan(w) substitution.
  • · Replies 40 ·
  • · Replies 21 ·
