Calculating Initial Bullet Speed in Bullet-Block Collision on a Table
  • Thread starter Thread starter billiam
    Block Bullet
An 8.00 g bullet is fired into a 250 g block, which falls from a 1.00 m table and lands 1.5 m away. The time for the block to hit the ground is calculated to be approximately 0.4517 seconds. The initial calculations incorrectly assumed constant acceleration during the block's horizontal motion, leading to errors in determining the bullet's initial speed. The correct approach involves finding the horizontal velocity of the block and bullet system after the collision using conservation of momentum. This method clarifies the relationship between the bullet's speed and the block's movement post-impact.
billiam
An 8.00 g bullet is fired into a 250 g block that is initially at rest at the edge of a table of 1.00 m height (Fig. P6.30). The bullet remains in the block, and after the impact the block lands d = 1.5 m from the bottom of the table. Determine the initial speed of the bullet.
this is what i did:
time for block to hit floor:
x = ut + 0.5at^2
1.0 = 0.5*9.8t^2
t = 0.4517 seconds
acceleration needed to move block 1.5 meters in t seconds
1.5 = 0.5a*0.4517^2
a = 14.7
velocity at time of hitting the ground:
v=u+at
v=6.63999 m/s
mv = (m+M)V
.008v = (.258)6.63999
v = 214.139m/s
this is the wrong answer; could someone give me a hand?
thanks
bill
While the block falls, it is not accelerating in the x direction, but merely has a velocity. You know it travels 1.5m in 0.45 seconds, so find the velocity of the block+bullet system after the collision. From there I would try energy methods, since its a perfectly inelastic collision.
1.5 = 0.5a*0.4517^2
a = 14.7
This is your error. This formula assumes a constant acceleration throughout the motion. That is not true here. The bullet gives an "instantaneous" acceleration to the block. After that, there is no horizontal acceleration.
Assume the block(and bullet) has some initial horizontal velocity v0 m/s and acceleration 0. Then the distance the block moves in t seconds is given by v0t. Assuming your value for t is correct (I didn't check that) you can solve v0(0.4517)= 1.5 to find v0.
Now, use conservation of momentum with the velocity you just found to find the velocity of the bullet just before hitting the block.
Thank you guys so much. I am a moron; wasted an hour on this question.
