Bullet is fired and hits a block. find KE and Speed?
The discussion centers on calculating the kinetic energy of a bullet and the speed of a bullet-block system after an inelastic collision. The kinetic energy of the bullet can be determined using the formula KE = 0.5mv^2, where the mass is 1.0 kg and the velocity is 1000 m/s. For the bullet-block system, momentum conservation is key; the initial momentum of the bullet must equal the final momentum of the combined bullet and block. The problem is classified as a perfectly inelastic collision, where the bullet embeds in the block, resulting in a combined mass and a new velocity that can be calculated by equating initial and final momentums. Understanding that kinetic energy is not conserved in this scenario is crucial for solving the problem.
physics1007
A 2.0-kg pistol fires a 1.0-kg bullet with a muzzle speed of 1000 m/s. The bullet then strikes a 10-kg wooden block resting on a horizontal frictionless surface. The block and the embedded bullet then slide across the surface.
A) what is the kinetic energy of the bullet as it travels toward the block?
B) what is the speed of the "bullet+block" system immediately afer the bullet is embedded in the block?
I have the KE=.5mv^2-.5mv0^2 equation and substituted my numbers and am unsure how to solve part B. Also could someone explain part a for me. Thanks.
To determine the velocity of the system in part B keep in mind that momentum will be conserved. Muzzle velocity is the speed of the bullet relative to the gun, the gun shoots the bullet and recoils so the velocity of the bullet in the frame of reference of the block will be lower than 1000 m/s. Again, momentum will be conserved after the gun shoots the bullet.
^I don't think they want you to go that deep into it. This is a simple inelastic collision in which momentum is conserved. The mass of the system increases, so what happens to the velocity?
Some textbooks classify this type of a problem as a perfectly inelastic collision. For this type of collision, two objects, intially separate, collide and stick together. The momentum of the system is conserved, but the kinetic energy of the system isn't. In fact, it can't be conserved for such a scenario, so energy conservation won't help.
The last part of your question says, "The block and the embedded bullet then slide across the surface". Seems that the new system is the sum of the masses of the block and the bullet. Momentum conservation says the initial momentum of the system should be equal to the final momentum of the system.
Simply equate your initial and final momentums and solve for the final velocity of the system as a whole.
