Calc 3 Factoring a Trig equation
lukasz08
can you somehow factor the following equation ? sqrt(9sin^2(t)+16cos^2(t)+1/4)
Using sin^2 + cos^2 =1, you can simplify the expression inside the sqrt in 2 ways (cos^2 only or sin^2 only with + constant for either). Try it and see if you can do something with it.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
