Calculate acceleration of object with applied force and friction
A worker pulls a crate with a force of 450 N at a 38-degree angle, while a frictional force of 125 N opposes the motion. The horizontal component of the pulling force is calculated as 354 N, and after accounting for friction, the effective force is 229 N. The acceleration of the crate, with a mass of 310 kg, is determined using the formula a = F/m, resulting in an acceleration of 0.74 m/s². The initial miscalculation arose from incorrectly considering the net force in both x and y directions instead of focusing solely on the horizontal component. The final correct acceleration reflects the influence of friction and the angle of the applied force.
username12345
A worker drags a crate across a factoryt floor by pulling on a rope tied to the crate. The worker exerts a force of 450 N on the rope, which is inclined 38 degrees to the horizontal, and the floor exerts a horizontal frictional force on 125 N that opposes the motion. You can assume the crate doesn't leave the ground.
Calculate the acceleration of the crate (mass = 310 kg).
F = ma
Broke the force of the pull into x and y components:
Fx = 450 cos 38 = 354 N
Fy = 450 sin 38 = 227 N
Then the friction opposes motion, so subtract that from the x component
Fx = 354 - 125 = 229 N
so the net force is \sqrt{229^2 + 227^2} = 322 N
then, a = \frac{F}{m} = \frac{322}{310} = 1.0 ms^{-2} to 2 s.f.
However the answer given is 0.74 ms
You're doing well until
The crate does not leave the ground so the only acceleration will be in the x-direction.
Ah, got it...
a = \frac{F_x}{m} = \frac{229}{310} = 0.74
Thanks.
