Calculate acceleration of the system
To calculate the acceleration of the system involving a 28.0 kg block and a 1 kg bucket, one must first determine the mass of sand needed to initiate movement. The forces acting on the block include gravity, normal force, and friction, while the bucket experiences gravity and tension from the cord. The tension in the cord is equal to the gravitational force acting on the bucket, and both tensions are consistent throughout the system. By applying the equations of motion, specifically the sum of forces equals mass times acceleration, the necessary calculations can be performed. This approach allows for the determination of both the mass of sand added and the system's acceleration.
briiannnaa04
A 28.0 kg block is connected to an empty 1 kg bucket by a cord running over a frictionless pulley. The coefficient of static friction between the table and block is 0.320. Sand is gradually added to the bucket until the system just begins to move. a) calculate the mass of sand added to bucket. b) Calculate acceleration of the system
Sum of forces=MA
Ff=uFn
You are supposed to write up your attempt - surely you have something, perhaps the diagram of forces or equations for the sum of forces = ma on each object.
i really don't know how to start it, i drew a diagram but I am not sure what to do next
What forces act on the bucket?
What forces act on the block?
gravity and the normal force
The normal force, gravity, friction?
The bucket has gravity acting on it and the tension in the cord. The block has gravity, friction and the tension in the cord. The tensions in the cord are THE SAME.
When the tension in the cord is equal to the force of friction ANY SECOND after this the system is going to start moving. Is there any way you can define the tension in the cord using the forces on either the bucket or the block?
Great - you are started! Now use the two formulas you listed.
Tension in the cord on the bucket is equal to the gravitational force?
Yes, the tension in the cord is equal to the gravitational force of the bucket. Both tensions are the same.
