Calculate center of gravity of eco marathon aka supermileage
To calculate the center of gravity for a supermileage vehicle, specific dimensions and weight limits must be considered, including a maximum height of 100 cm, a track width of at least 50 cm, and a total vehicle weight limit of 140 kg. The discussion emphasizes the importance of understanding mass distribution within the vehicle, as this is crucial for accurate calculations. Without detailed information on how weight is distributed across the vehicle, precise calculations cannot be made. Additionally, using extreme limits for variables is not advisable for practical design. Accurate center of gravity determination is essential for optimizing vehicle performance and stability.
jimmyctsean
Hi, hope someone can help. I need to find the centre of gravity of a supermileage.
Here is the dimensions:
~The maximum height must be less than 100 cm.
~ The maximum height measured at the top of the Driver's compartment must be less than 1.25 times the maximum track width between the two outermost wheels.
~ The track width must be at least 50 cm, measured between the midpoints where the tyres touch the ground.
~ The wheelbase must be at least 100 cm.
~ The maximum total vehicle width must not exceed 130 cm.
~ The maximum total length must not exceed 350 cm.
~ The maximum vehicle weight, without the Driver, is 140 kg.
Hope anyone can help! Urgent
There's no answer unless you want to put all variables at their extreme limits, which you wouldn't. Also you need to know more details of mass distribution, in fact that's all you need, and it's also what's missing.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
15K
