Calculate Change in Velocity of Flatcar When Man Runs Opposite Direction
The discussion focuses on calculating the change in velocity of a flatcar when a man runs in the opposite direction. The flatcar weighs 3000 N and moves at an initial speed of 16.8 m/s, while the man weighs 746 N and runs at 4.46 m/s relative to the flatcar. The correct increase in the speed of the flatcar is determined to be 0.888 m/s. Key equations used include the conservation of momentum: m1u1 + m2u2 = m1v1 + m2v2, and the calculation of mass from weight using F = ma.
  • Understanding of conservation of momentum
  • Ability to calculate mass from weight using F = ma
  • Familiarity with relative velocity concepts
  • Basic knowledge of kinematics
  • Study the application of conservation of momentum in different systems
  • Learn how to analyze relative motion in physics
  • Explore the effects of friction on moving objects
  • Investigate real-world applications of momentum in transportation systems
This discussion is beneficial for physics students, educators, and anyone interested in understanding momentum and motion dynamics in mechanical systems.
DavidAp
A man (weighing 746 N) stands on a long railroad flatcar (weighing 3000 N) as it rolls at 16.8 m/s in the positive direction of an x axis, with negligible friction. Then the man runs along the flatcar in the negative x direction at 4.46 m/s relative to the flatcar. What is the resulting increase in the speed of the flatcar?
Answer 0.888 m/s
F = ma
In my attempt I saw that I would probably have to work with the equation m1u1 + m2u2 = m1v1 + m2v2 since I was asked to find the difference in velocities. Knowing that i solved for the masses of each object.
Man (Object 1)
F = 746 N
m = 746/9.8 = 76.12 kg
Flatcar (Object 2)
F = 3000 N
m = 3000/9.8 = 306.12 kg
After that I rearranged the conservation of momentum equation to fit the problem stated above. Since, in the beginning, they can be treated as one object the equation is,
u(m1 + m2) = m1(u-v1) + m2v2
I also noted that the velocity of the man was relative to the flatcar so I took the difference of the two velocities and assigned it to the man. After having this I solved for v2 and plugged in the knowns.
v2 = [u(m1 + m2) - m1(u-v1)]/m2
v2 = [16.8(76.12 + 306.12) - 76.12(16.8 - 4.46)]/306.12
v2 = 17.909 m/s
However, when I go and calculate the difference I get... well, something that is not the answer!
Δv = vf - vi = 17.909 - 16.8 = 1.109 m/s.
What did I do wrong? Did I not understand what the question was asking of me?
Thank you for taking the time to read and review my question.
Answer 0.888 m/s
F = ma
Man (Object 1)
F = 746 N
Flatcar (Object 2)
F = 3000 N
v2 = 17.909 m/s
You are on the right track but the red part is not quite correct. Remember that once the man starts moving, the flatcar is no longer going at 16.8 m/s. How does that change your equation?
