Calculate Drag Force & Power for Long Cylindrical Antenna
The problem involves calculating the drag force and power required for a long cylindrical antenna mounted on a car moving at a specified speed. The antenna's dimensions and the kinematic viscosity of air are provided, along with the expected result for power.
  • Participants discuss the calculation of the drag coefficient and its dependence on the Reynolds number. There are questions about the accuracy of the drag coefficient obtained from a diagram and the implications of using different values. The original poster also seeks validation of their approach and calculations.
Some participants have provided feedback on the calculations, questioning the changes in force and power values. There is an acknowledgment of the potential inaccuracies in the assumptions made regarding the drag coefficient and the airflow around the antenna. The discussion remains open, with participants exploring different methods for determining the drag coefficient.
Participants note that the assumption of the antenna being in free airflow may not hold true in practical scenarios, as the presence of the car can influence the airflow around the antenna.
Nurah
A long cylindrical antenna of 9 mm (0.009 m) diameter is mounted vertically on a car moving at 100 km/h (27.778 m/s). Antenna is 920 mm long (0.92 m). Calculate the power required to move antena through the air with standard kinematic viscositiy ν = 1.46 ⋅ 10-5 m2/s.
The given result is P = 104 W.
2. Homework Equations
F = 0.5 ⋅ ρ ⋅ v2 ⋅ CD ⋅ A
where:
F - drag force
ρ = 1.2 kg/m3 - density of the air
v = 27.778 m/s - speed
CD - drag coefficient
A - relevant area
P = F ⋅ v
where:
P - reguired power
3. The Attempt at a Solution
First, I tried to find drag coefficient. To do that, I must find Reynolds number:
Re = (v ⋅ d) / ν
Re = (27.778 ⋅ 0.009) / (1.46 ⋅ 10-5)
Re = 17123.4
According to the diagram, for infinitely long cylinders, CD ≈1
Also, relevant area is:
A = diameter ⋅ height
A = 0.009 ⋅ 0.92
A = 8.28 ⋅ 10-3 m2
Now, the drag force is:
F = 0.5 ⋅ 1.2 ⋅ 27.7782 ⋅ 1 ⋅ 8.28 ⋅ 10-3
F = 3.83 N
Required power is equal to:
P = F ⋅ v
P = 4.37 ⋅ 27.778
P = 106.4 W
Is this the correct way to calculate this? Am I getting 2 watts more just because of "not so accurate" reading from the diagram above?
Thanks.
Why did the force change from 3.83 N to 4.37 N?
Where does the value for the density of air come from?
2% deviation is certainly fine if you take CD from the diagram.
Thanks for reply.
When I calculated the force for the first time, I read CD = 1.14 from the diagram and I got F = 4.37 N and P = 121.4 W, which was too much.
Then I realized that the CD might be a little lower, so in second reading from the diagram, I read CD = 1. Then I got F = 3.83 N and P = 106 W.
Since I typed that in a hurry, I missed to correct the value for the force in all equations. Sorry for that.
In the book where I found this example under the text it is said that the air has standard characteristics, so the density is 1.2 kg/m3.
So, this procedure is fine?
Is there any other way to calculate CD in this case, because the "reading from the diagram" method is not so accurate?
Thanks.
The assumption that the antenna is in a free air flow is not so accurate either. Usually car antennas are attached to cars, and those influence the air flow. Taking a value of 1 should be fine, you won't get a 1% accuracy anyway.
10K
14K
