Calculate Friction based on v, t, m & F
  • Thread starter Thread starter ital_dj
    Amp Friction
To calculate the force of friction acting on a dragster that reaches 350 km/h in 6.2 seconds, the net force equation Fnet = ma is applied. The acceleration was determined to be 15.68 m/s², leading to a calculated friction force of 10,944 N. This result is close to the textbook answer of 10,900 N, suggesting rounding differences. The discussion highlights the importance of understanding the relationship between driving force, mass, and acceleration in friction calculations. Overall, the participant demonstrates progress in grasping the concepts involved.
ital_dj
[SOLVED] Calculate Friction based on v, t, m & F
A dragster reaches 350km/h from rest in 6.2s. If the car is 800kg and generates a driving force of 1600N, find the force of friction acting on the car.
Fnet = ma
I tried converting, and then got lost from there. 350km/h is now 97.2m/s. What do I do now? How do I get friction... I know it's got something to do with gravity.
I just found out the acceleration which is 15.68m/s^2
Edit: I got 10944N for Ff, and the book is 10900N. I can't believe I'm even close, lol, but what did I do wrong? Or is it just the book rounding it, because I've found other numbers rounded.
The book rounded. You did it right if you got that answer.
Alrightt! Thanks... at least I'm catching on to some things, and won't fail that bad :)
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
