Calculate Impedance Magnitude & Phase of VR
  • Thread starter Thread starter Zell2
The discussion focuses on calculating the magnitude and phase of the voltage across a resistor in a series circuit containing a capacitor, inductor, and resistor, driven by an alternating voltage source. The impedance of each component is defined, and the user initially considers using a potential divider approach but struggles with determining the correct phase. Clarifications are provided regarding the need to consider the phase shift relative to the driving source and the importance of the order of components in the circuit. The conversation emphasizes the correct interpretation of "phase" in this context, specifically regarding the voltage across the resistor in relation to the source voltage. Understanding the phase relationship is crucial for accurately solving the problem.
Zell2
There is a circuit with an alternating voltage source and a capacitor (capacitance C) an inductor (inductance L) and a resistor (resistance R). The resistor has a potential VR marked across it.
Calculate the magnitude and phase of the voltage VR.
Impedance of resistor=R, impedance of capacitor=-j/wC, impedance of inductor=jwL, impendances in series add linearly.
My first though was just to treat it as a potential divider and its easy to find the magnitude. But I'm getting at bit confused about finding the phase of VR: can you just take the phase from the potential divider equation, so pahse relative to input voltage=-arctan((wL-1/wC)/R)? Possibly it's me trying to make things harder than they should be but it's from a past exam paper and was worth 12 marks so doesn't seem to involve much work?
Thanks
Thanks
Yes, except I don't know why you have negative arctan. Add the impedance of the inductor to the impedance of the capacitor (which is negative). The result gives you a net inductance or net capacitance.
The negative sign came from:
VR=RV/(R+jwL-j/(wC))
so I thought:
phase(VR)=-phase(R+jwL-j/(wC))
Is this right?
Thanks
so I thought:
Is this right?
Thanks
If you were using complex exponential form for the complex numbers, then yes, \frac{1}{e^x} = e^{-x}
But with the complex number in algebraic format like that, I don't think you can make the same assumption. It may be true, but I'd work it out first to be sure.
And your problem statement wasn't very clear. You have a series C-L-R circuit with the components in that order, and the phase you want is the phase shift from the driving source (which drives the top of the C with respect to the bottom of the R)? You need to be careful with the definition of "phase" in this problem. There is no phase shift across the resistor, obviously, so the "phase" that is being asked for has to be with respect to the driving source. And in that case, the order of the components makes a difference.
Yes that's the circuit.
I need the phase of the voltage across the resistance, (no direction specified), with respect to the voltage source. Sorry about the lack of clarity in the first post.
I'm a bit confused about the direction. The voltage across the resistor in the direction opposing the source voltage will the in phase with the current, and Vcomponents=(R+jwL-j/wc)I. but do I need the voltage in this direction or the opposite one?
Thanks
I would interpret the question as asking for the phase of the voltage waveform at the top of the resistor as compared to the zero phase of the driving source.
