Calculate magnitude and direction of mass's acceleration.
A 2kg mass hanging from a spring with a stiffness of 70N/m oscillates vertically under gravity. For part a, when the spring is stretched to 40cm, the force is calculated as -7N, leading to an acceleration of 3.5 m/s² downward when considering gravity. In part b, similar calculations apply for a stretch of 75cm, with adjustments for the new displacement. The discussion emphasizes the importance of including gravitational force in the total force equation, leading to the formula a = (-kx + mg) / m. Overall, the calculations and understanding of forces acting on the mass are confirmed as correct.
bob29
Question: "A block of 2kg mass is hanging from a spring with stiffness K=70N/m. The spring has an unstretched length of 30cm. The mass oscillates vertically under the influence of the spring and gravity. Calculate the magnitude and direction of the mass's acceleration when:
a) x=40cm
b) x=75cm
F = -kx
x = (L' - L) where L = unstretched
F = ma
F = mg
part a) F= -KX, F= -70*(0.4-0.3) = -7N, F=ma where F= -7N so a=m/F = (-3.5)j N,
direction of A is downward @ a magnitude of (3.5+9.8)ms^-2
part b) same as part a with the number change.
Not sure if it's correct, would like to know where I went wrong.
Cheers,
for both cases you should also consider the acceleration due to gravity which you haven't...
Not exactly sure on the formula but would it be Ftotal= mg + -kx ?
where g=-9.8ms^-2.
where g=-9.8ms^-2.
yes the force is right.. go ahead! :smile:
from there would it be correct if i were to let Ftotal=ma?
then ma = -kx + mg, so that a= (-kx + mg) / m
yes again :smile:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
