Calculate mass from acceleration and radius
The discussion revolves around calculating the mass of an object using gravitational acceleration and radius. The original poster seeks to understand how to derive mass from the given values of acceleration (2 m/s²) and radius (12 m), referencing the gravitational constant.
  • The original poster attempts to apply the formula F=GM/r² and subsequently derive mass using M=F/A. Some participants question the application of the formula and clarify the relationship between mass and gravitational acceleration.
Participants are exploring the problem with varying interpretations. Some guidance has been offered regarding the correct application of gravitational equations, and there is an ongoing dialogue about the implications of the given parameters. The original poster expresses confusion about the problem setup and seeks further clarification.
The original poster is calculating the mass of an imaginary planet, which introduces unique constraints, such as the specified radius and acceleration due to gravity. There is a mention of the density of the planet, suggesting further exploration of related concepts.
kmh36
How do you calculate the mass of an object just from the acceleration from gravity and the radius?
My thoughts were F=GM/r2, then once you find F, you can calculate mass by M=F/A
G= 6.67 x 10^11
r = 12
Acceleration = 2 m/s^2
(6.67 x 10 ^-11) / 12^2 = 4.63 * 10 ^-13
M = (4.63 * 10 ^-13)/(2 m/s^2) = 2.31 ^-13 kg
Hello 10 m/s, and welcome to PF :smile:
Acceleration from gravity due to another object happens to be independent of mass. You are missing an m in your ##F = {G Mm\over r^2}## that, with ## F= ma## goes over in ##a = {G M\over r^2}##.
[edit] compare gravitational acceleration at the surface of the earth:
G = 6.67E-11 N/(m/kg)2
M = 5.97E+24 kg
r = 6.37E+06 m
g = GM/r2 = 9.82E+00 m/s2
I'm sorry, I still don't understand! What is 10 m/s?
I didn't think my equations were right, but I really don't know what to try next. I don't know the mass which is really hanging me up.
10 m/s is 36 km/h, just a corny attempt at humor.
You don't know the mass in what kind of situation ? Could you be a bit more elaborate in the problem statement ?
Apparently you have two "things", 12 m apart, and "something" accelerates with 2 m/s2 ?
Ha, that is funny!
I'm trying to calculate the mass of an imaginary planet. All I have given to me is the radius (12m) and the acceleration due to gravity on that surface (which is 2 m/s2)
Well, then you're in business! So the problem statement is:
What is the mass of a planet with radius 12 m (!?), given that the acceleration due to gravity on the surface of that planet is 2 m/s2.
And you have the equation. Is it clear that GM/r2 is not a force but an acceleration ?
It's a very dense planet. Just for the fun of it, calculate the density in kg/m2 assuming its a sphere...
tip: work in symbols (a, G, M, r) as long as you can, until you have a final expression (a = ...) . Then check dimensions and then fill in numbers.
  • · Replies 23 ·
  • · Replies 21 ·
