Calculate Normal Force: Crate & Person on Floor
The discussion revolves around calculating the normal forces acting on a crate and a person standing on it. The crate has a mass of 41 kg and the person weighs 67 kg, leading to a calculated normal force of 1080 N from the floor on the crate and 670 N from the crate on the person. Participants suggest drawing force diagrams and summing forces for clarity. There's a debate about using 10 m/s² versus the more accurate 9.8 m/s² for gravitational acceleration, with a consensus that answers should reflect the precision of the values used. The importance of specifying units in calculations is also emphasized.
Pizza Dave
Please help with below. is it correct?
A 41 kg crate rests on a horizontal floor and a 67kg person is standing on the crate.
a. determine the magnitude of the normal force the floor exerts on the crate
b. determine the magnitude of the normal force that the crate exerts on the person
(m1+m2)G
M2(G) [/B]
a. 1080
b. 670 [/B]
Likes carl_loves_math
Try drawing a force diagram for both the person on the crate and the crate and try summing your forces for each individually. The answers should become clear!Also, this belongs in introductory physics.
AlephNumbers, this was an impertinent response.
Pizza Dave, you calculated this answer correctly, but it looks like you substituted 10 for the force of gravity instead of the actual value of 9.8. This may help your answers be more accurate in the future!
Pizza Dave said:
a. 1080
b. 670
You should always specify units (unless instructed otherwise).
Both values are just approximations. Often students are told to use 10 ms-2. On the other hand, if it is approximated to 10 then, logically, the answers should only be given to the same precision, e.g. 1100 N for (a).
And you mean gravitational acceleration, not force.
