Calculate resistivity of the material of the wire
To calculate the resistivity of an iron wire with a current of 0.75A and a voltage of 1.5V, the resistance is first determined using R = V/I, resulting in 2Ω. The resistivity formula R = ρl/A is then applied, substituting the known values: length (5m) and area (2.5 x 10^-7 m²). The calculation leads to a resistivity of 1 x 10^-7 Ωm. The final answer is confirmed as correct by participants in the discussion.
looi76
[SOLVED] Calculate resistivity of the material of the wire
Question:
0.75A Current flows through an iron wire when a battery of 1.5V us connected across its ends. The length of the wire is 5m and Area is 2.5 \times 10^{-7} m^2. Calculate resistivity of the material of the wire.
Equation:
R = \frac{Pl}{A}
Attempt:
I = 0.75A \ , \ V = 1.5V \ , \ l = 5m \ , \ A = 2.5 \times 10^{-7} m^2
R = \frac{Pl}{A}
P = IV
P = 0.75 \times 1.5
P = 1.125
R = \frac{1.125 \times 5}{2.5 \times 10^{-7}}
R = 2.3 \times 10^7
Is my answer correct?:confused:
You have your P's mixed up :rolleyes:
The P here represents the resistivity of the material
looi76 said:
R = \frac{Pl}{A}
Whereas the P here represents the power dissapated by the wire.
looi76 said:
P = IV
Thanks Hootenanny!
R = \frac{V}{I} = \frac{1.5}{0.75} = 2\Omega
R = \frac{Pl}{A}
2\Omega = \frac{P \times 5}{2.5 \times 10^7 \Omega{m}}
P = \frac{2 \times 2.5 \times 10^{-7}}{5}
P = 1 \times 10^{-7} \Omega{m}
is this correct?:rolleyes:
looi76 said:
Thanks Hootenanny!
R = \frac{Pl}{A}
That's what I get :approve:
