Calculate the angular velocity of the milk carton
The discussion revolves around calculating the angular velocity of a milk carton, specifically focusing on the moment of inertia and the center of mass during tipping. The problem appears to involve concepts from rotational dynamics and mechanics.
  • Mixed
  • Participants explore the moment of inertia about different axes and question the assumptions regarding the carton being empty or full. There are discussions about the height of the center of mass and its implications for the calculations.
Several participants have provided insights into the calculations needed, including the use of the parallel axes theorem and the moment of inertia formula. There is an ongoing exploration of the assumptions made regarding the carton’s contents and geometry, with no clear consensus reached yet.
Participants note that the problem does not explicitly mention the state of the liquid inside the carton, leading to assumptions that may affect the calculations. There are also references to previous discussions that suggest ignoring certain complexities like sloshing liquid.
javii
Is it correct?
javii said:
Is it correct?
No. You need to use the moment of inertia about the corner of the carton and you need to find the correct height of the center of mass when tipping occurs.
Maybe this problem does not intend to involve the full complexity of this situation, but milk cartons are not "full" of liquid, even when new. The movement of the liquid inside the carton would need to be accounted for in a full solution, IMO.
That is true, but since no mention is made in the problem about liquid in the carton, we may assume that it is empty. It could an empty carton on a cafeteria conveyor belt on its way to the trash disposal area. :smile:
On edit: Of course, the moment of inertia of an empty carton is more complicated to calculate.
It's also an issue for cartons that are full. The milk would tend to rotate internally in the opposite direction.
But an earlier part of the question says to ignore any sloshing around https://www.physicsforums.com/threads/calculate-the-maximum-acceleration-of-a-milk-carton.911818/.
There is another complication. Is it easily shown that the carton does not lose contact with the ground?
So, the formula i have to use is:
1/3*m*(b^2+l^2)?
and when i use that one i get
which leads me to:
so the angular velocity is 9.15 rad/s ?
1/3*m*(b^2+l^2)?
Why are you dividing the 0.195 by 2 but not the 0.07?
javii said:
which leads me to:
And why do you think the CM is at height ##\frac{0.195}{2}~m## just before the carton tips over? That's its height when the carton sits flat on the conveyor belt.
For me, it is obvious that I have to divide 0.195 with 2, but I am not sure if 0.07 also have to be divided with 2 since the carton is
skewed.
So your are saying, that I also have to divide 0.07 with 2?
Yes, but it is important to understand why. Start with ##I_{CM}=\frac{1}{12}M(l^2+a^2)## and apply the parallel axes theorem. Try using symbols, not numbers. What do you get?
I_p= 1/12M(l^2+a^2)+M+d^2
I_p=1/12M*l^2+1/12*a^2+M+d^2 ?
I see, it is a mistake by me. Its just the height.
Thanks
I assume you mean Md2, not M+d2.
What is d2 in terms of l and a?
Thanks
So what do you get now for the vertical displacement of the mass centre?
  • · Replies 30 ·
  • · Replies 17 ·
