Calculate the avg speed phyics help
  • Thread starter Thread starter deaninator
    Phyics Speed
To calculate the average speed of the caiman, the total distance of 530 meters is divided by the total time taken. The caiman swims 190 meters at 6 m/s, taking 31.67 seconds, and then swims 340 meters at 4 m/s, taking 85 seconds. Adding these times results in a total of 116.67 seconds. The average speed is then calculated as 530 meters divided by 116.67 seconds, which yields approximately 4.54 m/s. The calculation was confirmed to be correct by participants in the discussion.
deaninator
"Calculate the avg speed" phyics help
A caiman swims 190 meters at a speed of 6 m/s. It then enters a stream and slows to 4 m/s for 340 meters. What is the average speed of the crocodile?
10 minutes ago - 4 days left to answer.
You have two distance and speed sets from which you can get times. Add the times and add the distances, now you have a new r = D/t.
I did that. I added 190m and 340m and I got 530m as the total distance. I did the v=d/t formula on both distances and i got the times as 85 s and 31.66 s. I then divided 530m.116.66 s and i got 4.54 m/s but that is incorrect.
Your numbers appear correct.
Thanks, you were right all along!
