How to Calculate Magnetic Flux Through a Desk?
  • Thread starter Thread starter mrlucky0
    Flux
To calculate the magnetic flux through a desk measuring 4.3 m by 2.0 m in a magnetic field of 0.32 mT directed at 45° below the horizontal, the formula used is Flux = B*A*Cos(a). The calculated flux is 0.00194596 T*m, but the units should be T·(m^2). Concerns were raised regarding the magnetic field strength, as typical values for Earth's magnetic field range from 30 to 60 microteslas (0.03 to 0.06 mT). It is suggested to double-check the decimal placement in the magnetic field value provided. Accurate calculations and correct values are crucial for determining magnetic flux.
mrlucky0
A horizontal desk surface measures 4.3 m by 2.0 m. If the Earth's magnetic field has magnitude 0.32 mT and is directed 45° below the horizontal, what is the magnetic flux through the desk surface?
Flux = B*A*Cos(a)
Where A is the area, B is the magnetic field,
Flux = B*A*Cos(a)
= (.32E-3 T) * (4.3*2.0 m^2) * ( Cos(45) )
= 0.00194596 T*m
However, the my solution isn't correct and I'm convinced that I'm not doing anything incorrectly.
mrlucky0 said:
Flux = B*A*Cos(a)
= 0.00194596 T*m
I don't see anything wrong with your calculation either (other than that the units of flux should be T·(m^2).
I am a bit troubled by the value given for the magnetic field strength. For Earth, this value should be more like 30-60 microteslas or 0.03-0.06 mT. Are you sure about the location of the decimal point in the problem?
