Calculate the force on a particle from magnetic field of infinite wire
To determine the magnetic force on a charged particle near an infinite wire carrying current, the magnetic field strength can be calculated using B = μ₀i / (2πr). The force on the particle is given by F = q*v*B*sin(θ), leading to the combined equation F = (q*v*μ₀*i*sin(θ)) / (2πr). While the equation is correct for a specific radius and angle, it is noted that the magnetic field is non-uniform, affecting sin(θ) and r during the particle's trajectory. The discussion also touches on the notation for current, clarifying that "i" is commonly used for current in physics, while engineers prefer "j" for the imaginary unit. Overall, the calculations and concepts presented are validated by peer feedback.
eviljay
Problem: Determine an expression for the magnitude of the magnetic force on a charged particle moving near an infinitely long wire, carrying a current i.
  • Particle with charge q
  • Magnitude of the particles velocity = |v|
  • Magnetic field strength = B
  • Current = i
B can be calculated with:
B=\frac{μ_{0}i}{2\pi{r}}
Magnitude of force can be calculated with:
F=q*v*b*sin(θ) (Cross product of the particles velocity vector and the magnetic field vector)
I've combined these equations to come up with a single equation for the magnitude of the force on the particle:
F=\frac{q*v*μ_{0}*i*sin(θ)}{2\pi{r}}
However this final equation is the part I am not confident on. I've proceeded on the basis the the magnetic field around an infinite wire carrying current is non-uniform; that is the direction of the magnetic field is not constant, but would appreciate my working being checked!
Thanks in advance!
The magnetic field is not constant, this will change sin(θ) and r in a trajectory. But the equation for the force at a specific radius with a specific angle is correct.
Current is written with a capital I. "i" is usually the imaginary unit.
Looks good.
BTW i = √(-1) is only for physicists.
Real men (engineers) use j = √(-1) and i is very regularly used to denote current :smile:
Physics Forums > Science Education > Homework & Coursework Questions > Introductory Physics >
And mathematics as well.
Yeah, but not real men (and women)! :smile:
Thanks both! Just needed that extra pair of eyes to look at it :smile:
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
