Calculate the length of the thread -
  • Thread starter Thread starter engboysclub
    Length Thread
To determine the total length of the string in the world's largest ball of string, the volume of the sphere was calculated using a 2-meter radius. The string was modeled as a cylinder to find its height, using the cylinder volume formula. The discussion clarified that the problem seeks an answer to the nearest order of magnitude, meaning an approximate value within a factor of ten is acceptable. Participants emphasized that being off by a factor of two or three is generally permissible in such calculations. Understanding the concept of "order of magnitude" is crucial for approaching similar problems.
engboysclub
The world’s largest ball of string is about 2 meter in radius. To the nearest order of magnitude, i.e.,
the power of ten, determine what is the total length of the 4mm diameter string in the ball?
I calculated the volume of the ball "(considering it to be a sphere), using 2m as radius - After getting the value, I assumed the thread to be a "cylinder" and used "Cylinder's volume formula" --- V=Pie x R(squared) x H and calculated H ..
Is that correct ?
engboysclub said:
Is that correct ?
Sounds like a reasonable enough approach that should get you within a factor of ten.
Factor of ten ? What does it exactly means ?
We call it "Tenths, Hundredths, etc " - I have an idea, but please elaborate so I may not have confusion ever.
From the original problem statement: "To the nearest order of magnitude, i.e.,
the power of ten", meaning that they are not asking for an exact answer, but rather one that gives you an idea about the magnitudes we're dealing with. Generally when a problem is stated that way, an answer that is off by a factor of two or three in either direction is acceptable.
Perfect ! Thanks a lot !
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
