Calculate the pressure of the following mixture.
  • Thread starter Thread starter marcoskids
    Mixture Pressure
The discussion focuses on calculating the pressure at various depths in an oil reservoir, specifically at the water/oil contact (WOC) and depths of 12500, 11700, and 11000 feet. The pressure is calculated using the formula P = rho g h + Patm, with densities for water, oil, and gas provided. The initial calculation for pressure at WOC is approximately 64.7 MPa, but there is confusion regarding the correct height to use for subsequent calculations. Various attempts to calculate pressures at different depths yield different results, indicating a need for clarity on which densities and heights to apply. The conversation emphasizes the importance of correctly applying the principles of hydrostatic pressure in multi-phase systems.
marcoskids
An oil reservoir contains at water/oil contact (WOC) of 12000ft contains a water column at 800ft, oil at 500ft and gas at 600ft height
Calculate the pressure at WOC, 12500, 11700 and 11000 ft?
P = rho g h + Patm
1 ft = 0.305m
Rho water = 1000
Rho Oil = 800
Rho gas = 120
P WOC = 1000*9.81*(12000*0.305) + 800*9.81*(12000*0.305)+patm = 64.7Mpa
For the water column for example would the pressure be:
Pwoc + (1000*9.81*(800*0.305) = 67.1Mpa ?
or
Pwoc + (1000*9.81*((12000-800)*0.305)) = 98.2Mpa
or
Pwoc+(1000*9.81*((12000+800)*0.305)) = 102.3Mpa
Basically what height do I have to use?
And what densitys do I need to use for the depths at 12000, 11700 and 11000ft please?
New approach does this look better?
Pwoc = (rhoWgh ) + (rhoOgh)
= (1000*9.8*(12000*0.305)) + (800*9.8*(12000*0.305)
= 64.6 Mpa
Pgoc = (rhoG gh) + (rhoO gh)
= ((120*9.8*((12000-800)*0.305))) + (800*9.8*((12000-800)*0.305)))
= 30.8 Mpa
P12500 = (rhoW gh)
= 1000*9.8*(12500*0.305)
= 34.7 Mpa
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
