Calculate the speed of other car
  • Context: High School
  • Thread starter Thread starter CatAteMyHW
    Car Speed
The discussion revolves around methods for calculating the speed of another car while driving. Participants explore various approaches, including a proposed method based on timing and fixed points, as well as alternative suggestions like using a radar gun. The conversation touches on assumptions, potential errors, and the practicality of different techniques.
  • One participant proposes a method involving timing how long it takes for the other car to reach fixed points on the road, leading to a calculation of the other car's speed relative to their own.
  • Another participant suggests using a radar gun for a more straightforward measurement, adding their own speed to the reading.
  • Concerns are raised about the denominator in the proposed calculation, with some participants questioning whether it should be 'y' instead of 'y-1'.
  • Participants note that the proposed method calculates average speed and may not accurately reflect the speed if the other car is accelerating or decelerating significantly.
  • One participant suggests measuring the time it takes for the other car to pass their own vehicle, using the length of their car to calculate speed, but acknowledges the difficulty in accurately judging the timing.
  • There is discussion about the impact of parallax on measurements and the importance of conditions under which the calculations are made to minimize error.
Participants express differing views on the accuracy and practicality of the proposed methods. There is no consensus on the best approach, and multiple competing ideas remain unresolved.
Participants acknowledge various assumptions in their calculations, including the need for constant speeds and the challenges posed by parallax. The discussion highlights limitations in the proposed methods and the potential for error in real-world applications.
Individuals interested in practical physics applications, automotive enthusiasts, and those curious about speed measurement techniques while driving may find this discussion relevant.
CatAteMyHW
Hello everyone!
I was just wondering that while driving, is there a way to calculate speed of an other car that passes you?
I worked out a way but I needed more heads on this [that's what she..meh] so here's it:
When the car traveling faster than me goes pass me(me - carA;other car - carB), I fix a stationary point (pointA) ahead of carB on the road (like a tree). Now when carB passes that pointA, I start counting. I keep counting till I myself (CarA) reaches that pointA and note down the value (say x). Now while still counting I again fix another point (pointB) ahead of CarB and note down the value (say y) when it reaches there. Finally I note down the value (say z) when I (CarA) reach that pointB.
From this CarB's speed turns out to be ((z-x)/(y-1)) times my speed.
Now there's a lotta assumptions here because I wanted an "easy" method.
That was my take, could there be other methods (perhaps better than this)?
The easy method is to get yourself a radar gun and hold it out of your window. Add your own vehicle speed to the reading, and Bob's your uncle.
edit: Oops. I wrote that wrong the first time. Edited to fix.
Yes. That was the first thing on my mind but I realized buying one (or using it where I live) wouldn't be too easy for me for some reasons.
But isn't all-done-in-head way much cooler? I can see how this would seem trivial to you guys calculating and exploring speeds much much greater than vehicles. Now I'm not an expert in relativity and tensors and stuff but I'm a curious guy still exploring Newtonian physics and mathematics applicable in real world. With that I'll admit that I may be stoned when I first thought of all this :redface:
Why the denominator is y-1, it seems to me it has to be just y. (z-x)*your_speed=the distance between trees, and y is the time for car B to travel this distance.
Still this way u calculate the average speed over the distance between the trees, if the car accelerates a lot (or deccelerates) between the trees this calculation gives a result which is not close to the speed of carB as it reaches tree B.
Yea, thanks for seconding on that. I calculated it to be just 'y' myself. But when posting, I looked at the stunningly accurate graphic(/s) I made in MS paint and saw that carB is covering twice the distance than carA in each 'second' so something must've been wrong in my calculation d'oh!
Yup, lotta assumptions there to tone down the calculations. On a highway though, it's safe to say error would be less that ±10%, yes? After all, it's ultimately you who decides when is the right time to apply this to minimize error.
If you know the length of your car you could just count out the time he takes to move from about your rear bumper to the front. So V= L/t where L is the length of your car. His speed is then your speed + V. This will only be accurate if his speed is not a huge amount greater then yours.
It is not easy to judge just when a car in front of you passes so object. As your diagram shows there is a lot of parallax involved. Any of these methods are a guesstimate at best.
I think the mistake with the diagram is that you start from 1, where i believe you should start from 0.
I guess the error will not be big if you do the calculations when the velocities of both vehicles seem to be constant (like in big straight lines when the vehicles have reach their top speed).
Yup. In fact my intent was to have something better than just guessing "That car must've been above 100!". So as long as I take the measurements in just the right conditions I can guess with a level of certainty.
Yup. Though I'm relying on the brain's 3-D perception for minimizing parallax error:
hmm that's intriguing! Although you have to be know (by looking in rear-view) long before...
And wouldn't parallax be worse? I mean I always have trouble judging distances in rear-view rather than in front of me.
  • · Replies 16 ·
  • · Replies 46 ·
13K
  • · Replies 49 ·
  • · Replies 20 ·
  • · Replies 26 ·
