Calculate the volume of 1.00 mol of liquid water
To calculate the volume of 1.00 mol of liquid water at 20°C, the density of water (998 kg/m³) is converted to 0.998 g/ml. Using the molar mass of water (18.0 g/mol), the volume is determined by the formula 1 mole x 18 g/mol / 0.998 g/ml. The volume of 1.00 mol of water at the critical point is noted as 56 x 10^-6 m³. The discussion highlights confusion over a perceived mismatch in volume calculations, emphasizing the importance of unit conversions, particularly from m³ to cm³. Understanding these conversions is crucial for accurate calculations in chemistry.
Leo_lee
Calculate the volume of 1.00 mol of liquid water at 20°C (at which its density is 998 kg>m3),and compare that with the volume occupied by 1.00 mol of water at the critical point, which
is 56 * 10-6 m3. Water has a molar mass of 18.0 g>mol.
Full answer please!
Thanks,
1 mole x 18g/mole / .998 g/ml
First convert 998 kg>m3 to .998 g/ml
1 mole x 18g/mole / .998 g/ml = ___ml
Then do the same at Tc
But their number looks wrong to me. They're off by a factor >1000
hello Leo, :welcome:
Might first want to study PF guidelines a bit ...
Leo_lee said:
their number
How can I agree or disagree if you don't show it ? (or do you mean the 56E-6 ? That is correct)
Never mind.
Work out your way down to the answer and post your work in detail.
the numbers are up there in the problem !
So how come you claim a mismatch of > 1000 ?
What specific number looks wrong to you?
1.00 mol of liquid water at 20°C (at which its density is 998 kg>m3),and 1.00 mol of water at the critical point, which
Sorry, but I'm uncertain as to what specific question you are asking.
This looks correct.
Here's where I'm not sure what you are referring to.
I don't !
OK, it's a conversion problem.
1 m3 = (1 m) x (1 m) x (1 m). Express each 1 m as so many cm.
