Calculate the volume with a rational funtion
  • Thread starter Thread starter yaakob7
    Rational Volume
yaakob7
Calculate the volume (V) generated by the given function:
y^{2}=\frac{x^3}{2a-x} about the line x=2a
I suppose you have to use cylindrical shells [because it's difficult to fin y], so:
V=2\pi(2a-x)\sqrt{\frac{x^3}{2a-x}}Δx
now:
V=\int^{2a}_{0}2\pi(2a-x)\sqrt{\frac{x^3}{2a-x}}dx
but I tried a million things but nothing works:
First, simplifying the integrand to this:
V=2\pi\int^{2a}_{0}\sqrt{2a-x}\sqrt{x^3}dx
Next, I've been searching for any substitution function, but nothing works. If you have some idea that could help me I'd be grateful.
Thanks
\displaystyle y^{2}=\frac{x^3}{2a-x} about the line x=2a
\displaystyle V=2\pi(2a-x)\sqrt{\frac{x^3}{2a-x}}Δx
now:
\displaystyle V=\int^{2a}_{0}2\pi(2a-x)\sqrt{\frac{x^3}{2a-x}}dx
\displaystyle V=2\pi\int^{2a}_{0}\sqrt{2a-x}\sqrt{x^3}dx
Thanks
Hello yaakob7. Welcome to PF !
Mostly it's just a matter of rewriting the integrand.
The substitution, u = 2a/x will also help. Do that first.
Did you mean u=2a-x??
I tried but the expression remains almost the same:
V=2\pi\int^{2a}_{0}\sqrt{u}\sqrt{(2a-u)^3}dx=2\pi\int^{2a}_{0}(2a-u)\sqrt{u}\sqrt{(2a-u)}dx
Im stuck there. I can`t find a simplify function that really works...
Good topic I read and i understanding
Hello nazfagge. Welcome to PF !
I'm glad that you understand this.
I'm stuck there. I can`t find a simplify function that really works...
Well, u = 2a/x was a typo.
I meant: Let u = x/(2a). Then x = (2a)u , and dx =(2a)du.
You can then factor 2a out of a whole lot of stuff.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
