Calculate Torque: Vector Products Homework
  • Thread starter Thread starter shell4987
    Vector
The discussion revolves around calculating torque using the vector product for a pebble subjected to a force. The force is given as (8.7 N)i - (4.2 N)k, and the position vector is (3.7 m)j - (6.5 m)k. The user successfully solved part (a) but struggles with part (b), repeatedly arriving at an incorrect answer of 0i + 6.21j + 0k. There is confusion regarding the interpretation of the position vector and its relation to the pebble's location, particularly whether the pebble is at the origin. Clarification on these points is sought to resolve the issue with part (b).
shell4987
Force = (8.7 N) - (4.2 N) acts on a pebble with position vector = (3.7 m) - (6.5 m), relative to the origin. What is the resulting torque acting on the pebble about (a) the origin and (b) a point with coordinates (5.0 m, 0, -1.7 m)?
The cross product torque=rxf
r'=r-d
I got part (a) correct, however I cannot get part (b) correct, I've done it about 5 times and it is completely wrong, my answers are: 0i + 6.21j + 0k. Can anyone tell me what I'm doing wrong?
How did one do the first part?
I'm a bit confused as to the position vector (3.7 m) - (6.5 m) and the pebble location. Is the pebble at the origin and the position vector is the moment arm of the force?
Force is Force = (8.7 N)i - (4.2 N)k and position vector = (3.7 m)j - (6.5 m)k, which is relative to the origin
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
