Calculate Work by Non-Conservative Forces for 1.10x10^3kg Car
  • Thread starter Thread starter Jacque77
    Calculation Work
The discussion focuses on calculating the work done by non-conservative forces on a 1.10 x 10^3 kg car moving up a mountain road. The car does 6.80 x 10^6 J of work while reaching a speed of 22.0 m/s at an altitude of 190 m. The user initially calculates the work done by the car as 2,335,960 J but realizes a mistake in their calculations. The correct approach reveals that the work done by non-conservative forces, accounting for friction and air resistance, results in a loss of energy totaling -4,464,040 J. The discussion highlights the importance of accurately applying the work-energy principle in physics problems.
Jacque77
The (non-conservative) force propelling a 1.10 x 10(3)-kg car up a mountain road does 6.80 x 10(6) J of work on the car. The car starts from rest at sea level and has a speed of 22.0 m/s at an altitude of 1.90 x 10(2) m above sea level. Obtain the work done on the car by the combined forces of friction and air resistance, both of which are non-conservative forces.
Calculate the work done by non-conservative forces using Wnc = dKE +DPE where
Wnc= W friction+W air+W engine
I used W1= .5MV2 + MGH
and
required W =W1-W
.5*1100kg*(22squared m/s) + 1100kg*9.8*192m = 2335960J
2335960-6800000 = -1655960J
What did I do wrong?
Work done on the car - work done by the car = loss of energy due to friction, air resistance.
the 2335960-6800000 gives -4464040 which is the correct answer. Too tired to see how unreasonable the first result was!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
