Calculating and Mixing NiAc and ZnAc Solutions for Molar Proportion
  • Thread starter Thread starter bilalarif
To achieve the desired Ni/Zn molar proportions of 1%, 3%, and 5% using 1M NiAc and ZnAc solutions, the calculations must reflect the correct ratios of the two components. For a 1% ratio, the calculation suggests using a total of 5 mmol of the mixture, resulting in 0.05 mmol of Ni and 4.95 mmol of Zn. However, this approach leads to a solution that does not maintain the original 1M concentration of Zn, thus failing to meet the requirement for a 1% molar proportion accurately. The correct method is to mix the solutions in a straightforward ratio based on the desired proportion. For a 1% ratio, mix the solutions in a 100:1 ratio, ensuring that the final concentrations are consistent with the original molarities. This principle applies similarly for the 3% and 5% ratios, where the mixing should reflect the specified proportions without altering the initial concentrations significantly.
bilalarif
I have been given NiAc and ZnAc solutions of 1M concentration. And being asked to mix the two solutions together in Ni/Zn nominal molar proportions 1%, 3% and 5%. How can I calculate and mix the two solutions to get the required molar proportion.
Chemistry news on Phys.org
Ni/Zn = 0.01, 0.03, and 0.05. Calculate it and do it.
Molar fraction = (number of moles of component of interest) ÷ (total number of moles of mixture)
For Ni/Zn nominal proportion 1%
0.01= number of moles of Ni/ total number of moles of Ni+Zn
Suppose we have total moles of (Ni+Zn) solution= 5 mmol
0.01= moles of Ni/ 5mmol
Moles of Ni = 0.05 mmol
Moles of Zn= total moles of (Ni+Zn)- moles of Ni
Moles of Zn= 4.95 moles
As both NiAc and ZnAc concentration is 1M.
M=n/V
V (ZnAc solution) = 4.95mmole/1 mol/l = 4.95ml
V (NiAc solution) = 0.05mmole/1 mol/l = 0.05ml
is it correct calculation?
That's one. Two to go.
No it isn't, though the error is small. You have made a solution which is 0.01 M Ni, but that is not what was asked for. It is not quite 1M Zn any more, so 1 % is not exactly the molar proportion.
If the starting molarities are equal an you are asked for a 1 % ratio you just mix them in the ratio 100:1.
You're probably so used to problems of achieving a given final molarity that you have overthught this one
Divalent ions, one to one.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
