Calculating Average Power Supplied from Phasors
1 reply · 4K views · last reply
ineedmunchies
Ok i have been given two trigonometric functions and asked to give them as phasors, and then calculate the average power supplied from this.
v = 311 sin (200t+7[tex]\circ[/tex]) V
i = 14 sin (200t - 16[tex]\circ[/tex]) A
I'm used to the trigonometric functions being in the cosine form, what difference will this make?
I believe it would be:
v = 311 [tex]\angle7[/tex]
and i=14[tex]\angle-16[/tex]
If it was given in the cosine form. And from there it would be possible to work out the average power.
Can anyone help me with this??
Also i know i might need to give the magnitude in RMS form.EDIT: Is it 83 degrees instead? and 74 for i?
Cosine leads sine by 90 degrees. If you wanted to use cosine to represent v and i, you would subtract 90 degrees rather than add 90.
Vm = 311
Im = 14
To convert to phasor form multiply Vm and I am by .707
Veff = 219.877
Ieff = 9.898
The angles remain the same.
Pavg = Veff*Ieff*cos(theta), where theta is the phase angle between v and i.
