Calculating Bending Moment and Microstrain in Hollow Circular Beam
The discussion centers around the calculation of bending moment and microstrain in a hollow circular beam subjected to a force at its midpoint. Participants explore the application of relevant equations and the proper use of units in the context of a homework problem.
  • Homework-related
  • The beam has an outside diameter of 350mm and a wall thickness of 60mm, with a length of 2m and a force of 200kN applied at the midpoint.
  • One participant calculated the moment of inertia (I) as 599.29x10^-6 m^4 and initially thought the bending moment was 100kNm but later noted it as 50kNm.
  • There is a calculation for microstrain based on bending moment and Young's modulus, with a derived value of approximately 44.92 microstrain.
  • Some participants point out errors in unit measurements, specifically regarding the measurement of 'y' and the calculation of the bending moment.
  • One participant emphasizes the importance of drawing a free-body diagram to analyze the beam and determine the reactions at the supports.
Participants express disagreement regarding the correct values for the bending moment and the proper interpretation of units. There is no consensus on the calculations presented, and multiple viewpoints on the approach to solving the problem remain.
Some participants highlight the need for clarity on unit conversions and the metric system, as well as the importance of static equilibrium in analyzing the beam.
This discussion may be useful for students studying structural engineering or mechanics, particularly those working on problems involving bending moments and material strain in beams.
rishi123
Hollow circular beam with outside diameter 350mm, and wall thickness of 60mm
E=60 Gpa
beam length 2m
Force applied to beam at midpoint of beam (1m from each end)
F=200KN
Force applie from the Top down, Ra , and rb from bottom up
Used o(bending)=My/I
Got I correct as 599.29x10^-6(m^4)
I think the bending moment is 100knm, but put in 50knm(wrong)
I was wondering if y=0.175(half of outside diameter in metres)
i got 14.60MPA(10^9) by doing, 50,000[bending moment]*0.175[y]/599.29*10^-6
When replacing 50,000 with 100,000 i get 29.201MPA, and for the microstrain i get:
E=65*10^9=29.201221*10^6/strain
rearrange for strain
strain = 29.201*10^6/65*10^9 = 44.92495067*10^ -5 or 44.92 microstrain
y is measured in meters, not meter^2.
Bending moment is measured in N-m
You need to brush up on units and how to calculate bending moments.
that was a mistake, an editing error
as later shown, y=0.175mm, ( which is the half of outside diameter )
could you eloborate on what i need to brush up on, where i can attain this information?
Add to the list above, need to work on metric system. Half of 350 mm is 175 mm, not 0.175 mm (which is a teeny-tiny measurement)
Working out bending moments starts with drawing a free-body diagram of the beam and figuring out the loads.
Once the FBD is in static equilibrium, you can construct the shear force and bending moment diagrams for the beam.
By inspection of the beam, it's easy to see that Rl = Rr = 100 kN. You should be able to figure out the moment from this information.
24K
10K
23K
  • · Replies 17 ·
