Calculating Constant speed of an Elevator Rising
To calculate the constant speed of an elevator with a motor power of 14 kW and a mass of 1100 kg, the relevant equations include gravitational potential energy (mgh) and kinetic energy (1/2 mv^2). The power produced by the motor can be equated to the work done per second, which is 14 kJ. To find the speed, one must determine how much height can be gained per second using the power output. The discussion highlights a need for algebraic manipulation to connect power, mass, and speed effectively. The key takeaway is that sufficient information is available, but proper application of physics principles is necessary for the solution.
Millacol88
The motor for an elevator can produce 14kW of power. The elevator has a mass of 1100 kg, including its contents. At what constant speed will the elevator rise?
I'm not really sure. Probably Gravitational potential = mgh. Kinetic energy = 1/2mv^2 because its looking for speed.
I'm really not sure. It doesn't seem like enough information is given to solve for anything. There's probably some algebraic manipulation I'm missing.
Consider work done per second (14 kJ) - what increase in height does that correspond to (14kJ = mgh)?
-S
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
