Calculating Current and Phase Angle in a Series RLC Circuit
  • Thread starter Thread starter kdrobey
    Circuit Current
The discussion revolves around calculating the current and phase angle in a series RLC circuit consisting of a resistor and an inductor connected to a generator. The circuit parameters include a 215-ohm resistor, a 0.200 H inductor, a frequency of 120 Hz, and a voltage of 235 V.
  • Participants discuss the use of impedance in calculating current, with attempts to apply the formula V = I * Z. Questions arise regarding the correct calculation of impedance and the relationship between the components in the circuit.
There is ongoing exploration of the correct approach to find the current and phase angle. Some participants have offered guidance on using total impedance, while others express confusion about their calculations and the implications of the impedance being less than the resistance.
Participants are working within the constraints of the problem statement and are questioning the assumptions made regarding the values used in their calculations, particularly concerning the impedance and its relationship to the circuit components.
kdrobey
A circuit consists of a 215 resistor and a 0.200 H inductor. These two elements are connected in series across a generator that has a frequency of 120 Hz and a voltage of 235 V.
(a) What is the current in the circuit?
(b) Determine the phase angle between the current and the voltage of the generator.
Xl=2(pi)fL
Irms=Vrms/Xl
I used the equation to get 150.796 for Xl, then i plugged that into the equation Irms=Vrms/Xl to find current, but that gave me 1.558, which was not the right answer
Your second equation in #2 above is incomplete. The resistor and inductor are in series, so you must use their total impedance in the V = I * Z equation. Does that fix it for you?
I'm still not getting it. I used V=IZ. I have V, which is 235 volts right? still, i did not have I or Z. So i used Z=(square root of)R^2 +(Xl-Xc)^2, and I got .89 for Z. Then plugging back into V=IZ, (235v)=I(.89)=262.49A for current?
Hi kdrobey,
For these series RLC problems the impedance is
[tex] Z=\sqrt{R^2 + (X_L - X_C)^2}[/tex]
and so the impedance cannot be smaller than the resistance, so something is wrong there. What were the actual numbers you used to calculate Z?
  • · Replies 30 ·
