Calculating electric field due to charge distribution
The discussion focuses on calculating the electric field due to a charge distribution, specifically addressing confusion about the distance used in the formula E = kq/r². Participants clarify that the distance r should be interpreted as (a + r - x), representing the distance from a segment of the charge distribution to a point P located to the right of the rod. The mention of charge q is deemed unnecessary for part (a), which concerns the electric field due to the total charge Q when x > a. Understanding this distance is crucial for correctly applying the electric field equation. The derivation remains valid when considering the correct interpretation of r in the context of the problem.
henry3369
http://imgur.com/EiCFIDe
E = kq/r2
λ = dq/dx
Q = λa
Here is the book solution:
http://imgur.com/aKSeKo0
I need help with part (a). I understand everything in the solution except for the distance they used for between (r2 in the equation above). It seems they used (a+r-x) and they say that is the distance between a segment at x and the charge q. What does q have to do with the problem at all? Part (a) asks for the electric field due to the charge distribution Q where x > a. So shouldn't the distance be between dx(a segment on the charge distribution) and x?
You are right, it should not have mentioned q in the solution for (a). But the derivation is OK if you think of r as the distance from the right end of the rod to some arbitrary point P located to the right of the rod.
