Calculating Electric Force and Distance Between Two Charges
The discussion revolves around calculating the electric force and distance between two charges, specifically with charges q1 = +2.65 nC and q2 = -4.75 nC, where q1 experiences a force of 55 μN from q2. Participants are exploring the implications of Coulomb's law in this context.
  • The original poster attempts to understand how to solve for two unknowns: the force on q2 and the distance between the charges. They express confusion about forming simultaneous equations and consider using electric field concepts. Other participants question the need to add forces and clarify that the force on q2 is equal to the force on q1, prompting further exploration of Coulomb's law.
The discussion is active, with participants providing guidance on the relationship between the forces acting on the charges. Some participants have clarified the application of Newton's third law, while others are still working through the implications of the equations involved.
Participants are navigating the constraints of the problem, including the need to derive two unknowns from limited information and the assumptions inherent in applying Coulomb's law.
shanie
Two small charges q1 = +2.65 nC and q2=-4.75nC are at a certain distance from each other. Q1 is affected by a force of 55μN from q2.
a) how large is the force on q2? Draw a figure that shows the electric forces that work on q1 and q2.
b) determine the distance between the charges.
a) coulomb's law: F= (k*qi*q2)/d^2
b) coulomb's law: F= (k*qi*q2)/d^2
a)Now I know that these questions are generally rather simple and straightforward, but what I cannot understand is how I'm going to solve the problem with two unknowns (the force on q2 and the distance). Because I only have a set of data I cannot really make a simultaneous equation out of it. I tried using E=F/q for q2 but then I only get E for one of the charges.. so how would I go on from there? I already drew a picture showing the two attracting forces with arrows toward each other (as one charge is positive and the other one negative).
b) Once I find the force on q2, I just add the forces together and make them equal to F in coloumb's law.. right? So then I just rearrange the variables and solve for d?
I could really use some help, thanks!
a) Think of Newton's laws. The answer is really simple when you see it.
Oh, you mean for every action there is an equal and opposite reaction? So if q2 works on q1 by 55μN, this means that q1 works on q2 by 55μN? So then in b) I just add them together to make 110μN, which I then plug into coulomb's law:
110 μN = (k*q1*q2)/d^2
And solve for d?
No, do not add the forces. Just use 55 uN for the force.
That equation gives the force F exerted by one charge on the other. They told you this force is 55 uN.
Oh, I see! Thanks :)
