Calculating electrons emitted question.
  • Thread starter Thread starter ConfusedElect
    Electrons
To determine the number of electrons emitted from the cathode each second, one can divide the number of photons striking the cathode per second by the charge of an electron, approximately 1.6 x 10^-19 coulombs. However, the resulting number may not seem realistic, indicating potential issues with the calculations or assumptions made. Understanding the current between the cathode and anode can also provide valuable insight into the electron emission rate. The user is seeking clarification on the appropriate equations and methods to accurately calculate this value. Accurate calculations are essential for a correct understanding of electron emission in this context.
ConfusedElect
Hi all, I realize the subsequent question is likely to be quite simplistic; therefore I apologise in advance and I hope I am not offending fellow users. Here’s the question: “How many electrons are emitted from the cathode each second?”
How would I go about answering this question?
I have previous calculated the energy of a photon and the number of photons striking the cathode each second.
Thank you in advance for any help provided :)
CE
I have calculated the energy of a photo using E=hf and I also have calculated the number of photons striking the cathode each second.
I am not sure of the equation for this problem as I am unable to locate it in my current Physics literature/I have also been unable to locate a relevant equation on the internet.
Would I divide the number of photons striking the metal per second by the charge of an electron? Therefore: (number of photons striking cathode each second)/1.6*10-19...
The numebr I obtain doesn't seem very realistic ;\.
Thank you :).
CE
Do you know the current between the cathode and anode?
(two threads merged)
Thank you very much :)!
CE
