Calculating Energy Transformed by Friction in a Falling Satellite
  • Thread starter Thread starter hauthuong
    Satellite
To calculate the energy transformed by friction as a satellite falls, start by applying the work-energy principle: KE_initial + PE_initial = KE_final + PE_final + W_friction. The initial kinetic energy can be calculated using the formula 1/2mv^2, while the potential energy requires the gravitational formula GM1M2/r^2. To find the initial velocity, consider the satellite's orbital speed at 500 km altitude. The final kinetic energy is determined by the impact speed of 2.00 km/s. Understanding these equations will help in solving the problem effectively.
hauthuong
A 500 kg satellite is in a orbit at an altitude of 500 km above the Earth's surface. because of the air friction, the satellite eventually falls to the Earth's surface, where it hits the ground with a speed of 2.00 km/s.how much energy was transformed into the internal energy by means of friction?
I really got no clue to solve this one. Could you guy give me some instructions? If you could, give me a lecture about this type of problem. Thank you
This is a work-energy problem. Consider solving the equation:
KE_0+PE_0=KE_f+PE_f+W_{friction}
Take the initial energy (potential plus kinetic) and subtract the final energy.
for kinetic energy I will us 1/2mv^2 .How do I find the V initial , Also, for Potential energy , I have to use GM1M2/r2 ? is it right? Thank you
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
