Calculating Equivalent Impedance in a Simple AC Circuit - Step-by-Step Guide
The discussion revolves around calculating the equivalent impedance of a simple AC circuit with given impedances Z1, Z2, Z3, Z4, and Z5. The user initially calculated Z_eq as 6.25 - i3.75, while their textbook states it should be 28.33. After verification, it was determined that if Z3 were incorrectly set to 5 + i20, the textbook's answer would be correct. The user confirmed their calculations were accurate based on the correct values of Z3. The conversation highlights the importance of ensuring accurate component values in impedance calculations.
tabsquare
hello I have a problem in calculating the equivalent impedance of a simple AC circuit, where the impedances are:
Z1 = 5+i20
Z2 = 5+i20
Z3 = 10-i2,5
Z4 = -i10
Z5 = 5
and I need to find:
Z_eq = Z3 // [(Z1 // Z4) + (Z2 // Z5)]
where the + indicates 2 components in serie and the // indicates 2 components in parallel.
My calculations always bring me to
Z_eq=6,25-i3,75
but my book says Z_eq=28,33.
Which is the correct eqv impedance?
Thank you
PS-I used the formula Za//Zb = (Za*Zb)/(Za+Zb)
to calculate equivalent impedances of two components in parallel, and the sum for components in serie.
Well, there's a mistake somewhere.
If I use the values you gave for Z1 to Z5, I get the same result you did.
However, if you set Z3 = 5 + i20, then you will get the result in the book.
Ok then there probably is a mistake in the book because Z3 is in fact equal to 10-i2,5 as I calculated and as the book reports. Lost some time on this stupid mistake...
Thank you very much for taking the time to verify this! :)
Riccardo
