Calculating Force and Kinetic Energy in an Electric Field
The discussion revolves around calculating the force and kinetic energy of an electron in an electric field between charged plates. The force on the electron is determined to be 8.058E-17 N directed downward due to the electric field of 503.0 N/C. The participants express confusion about how to calculate the increase in kinetic energy, particularly regarding the necessary velocity and the application of relevant equations. There is uncertainty about the meaning of "V" in the context of kinetic energy and electric potential difference, with suggestions that it may not be applicable to the problem at hand. The conversation highlights the challenges in understanding the relationship between electric fields, forces, and kinetic energy in this scenario.
adrianx
electric field
I can't find any straight forward solutions to this problem.. it's not addressed in the textbook (even though there is a chapter problem about it) and the internet doesn't have what I need either. I'm hoping someone could give me some insight on this.
An electron (q = -1.602 x 10^-19 C) is projected horizontally into the space between two oppositely charged metal plates. The electric field between the plates is 503.0 N/C, directed up.
(a) While in the field, what is the force on the electron?
(b) If the vertical deflection of the electron as it leaves the plates is 3.20 mm, how much has its kinetic energy increased due to the electric field?
For (a), I found the force to be 8.058E-17N down.
(b), I think I need to know what the velocity is. I know a few equations but I don't know how to use them for this.
The equations I know are:
K = (1/2)mv^2 which I found (on the 'net) to be equal to eV = (1/2)mv^2.
kinematic equations
F = ma = qE
Fot the second point,how about considering that the work done by the electric force is equal to the variation of the KE?
Daniel.
P.S.What "V" are u talking about?
Genius! The chapter and my professor didn't mention anything about work (or kinetic energy as it applies to the electric field for that matter).
Thank you so much :)
I don't know what that V is.. some webpages I found just used it. When I tried to apply it, I just used the elementary charge e (don't ask me why..)
That probably is the ACCELERATING (ELECTRIC) POTENTIAL DIFFERENCE.In this problem,it's unknown and moreover useless...
Daniel.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
