Calculating Forces on a Window Washer's Scaffold
  • Thread starter Thread starter physicsgurl12
    Forces Window
To calculate the forces on a window washer's scaffold, the problem involves determining the tension in two ropes supporting a 271.8N window washer and a 265.6N scaffold, which is 4.452m long. The washer stands 1.48m from one end, creating a need for equilibrium equations. A free body diagram is essential to visualize the forces acting on the system and to establish two equations based on the static conditions. The initial attempt at using kinematic equations is incorrect; the focus should be on statics principles to solve for the tensions in the ropes. Properly applying these concepts will yield the correct force values in each rope.
physicsgurl12
a window washer weighing 271.8N is standing on a scaffold by a vertical rope at each end. the scaffold weighs 265.6N and is 4.452m long. what is the force in each rope when the window washer stands 1.48m from one end.
1/2(m1+1/2 m2)Vf^2
1/2 (271.8+ 1/2 265.6N)1.48^2
i know this is wrong. i can't find the correct equation to use.
Do you know anything about statics?
You have two unknowns and you need two equations.
It would probbably help you if you would draw a picture. You need to make a free body diagram first.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
