Calculating Freefall Acceleration on the Moon
The discussion focuses on calculating the acceleration due to gravity on the Moon, given its mass and diameter relative to Earth. The participants explore the equations for gravitational force and acceleration, noting that the Moon's mass is one-hundredth that of Earth and its diameter is one-fourth. They derive the relationship between the gravitational acceleration on the Moon and that on Earth, ultimately determining that the Moon's gravity is approximately one-fourth that of Earth's. Confusion arises regarding the correct expression of the Moon's radius in terms of Earth's radius, which is clarified through further discussion. The final conclusion emphasizes the need to accurately substitute values to compute the gravitational acceleration on the Moon.
Ockonal
Mass of the Moon is nearly less in 100 times than Earth's, and the diametr is less in 4 times.
Find the acceleration of free falling at the Moon.
F = G×((M×m)/R²)
g = 9.8N
M_moon = M_earth / 100
D_moon = D_earth / 4
R_moon = D_moon / 2 = D_earth / 8
g_earth = G×(M_earth/R_earth²)
g_moon = G×(M_moon / R_moon²)
M_earth = (g×R_earth²) / G
M_moon = (g×R_earth²) / G / 100
g_moon = g_earth / 25
But the answer is wrong. I think my mistake is in diameter passing and converting it into radius. Help me, please/
Your mistake is that you dropped something. You were fine up to here:
Given that, what is g_moon / g_earth?
so:
g_moon / g_earth =
M_moon × R_earth²
M_earth × R_moon²
Now I'm passing data instead of *_moon:
(M_earth/100) × R_earth²
M_earth × (D_earth / 4)
How to make it easier?
so:
Code:
g_moon / g_earth =
M_moon × R_earth²
M_earth × R_moon²
Code:
I did this:
Code:
  M_earth × R_earth²
          100
M_earth × 2 × R_earth
R_earth / 25
But R_earth shouldn't be presented.
If the diameter of the Moon is roughly 1/4 of the diameter of the Earth, what can you say about the radius of the Moon in terms of the radius of the Earth?
D_moon = 1/4 D_Earth
R_moon = (1/4 D_Earth)/2
I'm confused :(
You just expressed the Moon's radius in terms of the Earth's diameter. I asked you to express the Moon's radius in terms of the Earth's radius. So, try again, please.
Once you have that figured out, go back to computing g_moon / g_earth.
you know that g=Gm/r2
now for earth
g = GM/R2
for moon, g' = GM'/R'2
you know that M' = M/100 and D' = D/4
so R' = ?
As I understand:
D/4 = Moon's diametr, so:
R/4 + R/4 = D/4
So radius is smaller in 4 times?
yes!
now just substitute the values
Didn't understand right, maybe:
Code:
g_moon = G × ( M_earth / 25 × R_earth² )
g_earth = G × ( M_earth / R_earth² )
g_moon / g_earth =
    M_eath × R_earth²
M_earth × 25 × R_earth²
1/25
the ' ones are for moon
g = GM/R2
so R' = R/4
Code:
g' = G(M/100)
      _______
        R/4
so ... g' = <something> GM/R[sup]2[/sup]
        g' = <something> g
Code:
g' = G(M/100)
      _______
        R/4
        g' = <something> g
Sorry, I can't understand from where did you get GM/R² in
Code:
g' = G(M/100)
      _______
        R/4
sorry i can't give answer ,,, got 2 warnings for it
i just rearranged the eqn and dividing the numbers i can
separate GM/R² ... and as you know from eqn of Earth GM/R² = g
eqn of Earth ... sounds fascinating!
