Calculating half power frequency/cutoff frequency
7 replies · 5K views
vishwesh
*(Problems attached as images)*
For first problem:
##\cfrac{|V_2|}{|V_1|} = \cfrac{1}{\sqrt{4+(\omega RC)^2}}##
For second problem:
##\cfrac{|V_2|}{|V_1|} = \cfrac{\sqrt{1+(\omega RC)^2}}{\sqrt{4 + (\omega RC)^2}}##
I have to calculate half power frequency for both cases.
At half power frequency, power absorbed by circuit = max power/2
[/B]
I cannot understand why the problem was solved differently in both cases. In first problem,##\cfrac{V_2}{V_1}## was set to ##\cfrac{1}{2\sqrt{2}}## and in the second problem it was set to ##\cfrac{1}{2}##. While in both problems, max value of ##\cfrac{V_2}{V_1}## occurs at ##\omega = 0## and is equal to ##\cfrac{1}{2}##.
Can someone please clear this doubt?
Thanks
Svein said:
Power = Voltage * Current
Thanks for the reply. But, I didn't get you. I am familiar with that formula. I understand that we use that formula to substitute ##\cfrac{|V_2|}{|V_1|} = \cfrac{1}{\sqrt{2}}## but how does it explain the ##\cfrac{1}{2\sqrt{2}}## part ?
Thanks again.
Thanks
Check again the frequency and maximum output for the second circuit. How do capacitors behave with frequency?
For the second solution shown, I think the magnitude of the voltage ratio should have been set to ##\frac{1}{\sqrt{2}}## rather than ##\frac{1}{2}##
Thanks for the reply. I think I got it. The max output should be 1 when ##\omega \rightarrow \infty##?
Yup. The capacitor starts to look like a short at high frequencies.
