Calculating Heat Energy from Falling Object
To calculate the heat energy produced by a 16 kg object dropped from 25 m, one must consider the conservation of energy, specifically the potential energy converted to kinetic energy and then to heat due to air friction. The potential energy (mgh) of the object is 3,920 J, while the kinetic energy at impact is 2,880 J. The difference, which accounts for energy lost to air friction, is 1,040 J. The correct answer to the heat energy produced is not explicitly listed in the options provided, indicating a possible miscalculation or misunderstanding of energy conservation principles. Understanding these concepts is crucial for solving similar physics problems effectively.
dragon513
Calculating heat energy...
Q. #1
A 16 kg object is dropped from a height of 25 m and strikes the ground with a speed of 18 m/s. How much heat energy was produced during the fall?
Choices
A) 0 J
B) 2 600 J
C) 1 300 J
D) 3 900 J
Well,according to my calculation, the average acceleration was about 6.48m/s, which means 3.32N/kg acted as air friction.
And I'm lost from there.
Help will be greatly appreciated!
HINT: Energy is conserved! :)
Like Tide said remember
\Delta K + \Delta U = W_{friction}
dragon513 said:
Q. #1
Choices
A) 0 J
B) 2 600 J
C) 1 300 J
D) 3 900 J
You don't have to work out force or average speed. Just use potential energy: mgh.
AM
ouch, I learned that a year ago and I have no idea how can I forget such thing ...Thx!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
