Calculating Initial Velocity for a Pendulum to Reach the Top Without Oscillation
To determine the minimum initial velocity (v0) for a pendulum mass (m) at an angle (θ) to reach the top without oscillating, the kinetic and potential energy must be correctly accounted for. The potential energy at the top is measured from the pivot point, which affects the height (h) calculation. The correct formula for v0 is derived from energy conservation principles, specifically v0 = √(2g(h_initial - h_final)). The height at the top is L + Lcos(θ), and the potential energy should be referenced to the pivot. Ensuring the correct reference point for potential energy is crucial for accurate calculations.
amcavoy
If a mass (m) at the end of a length (L) on a pendulum starts at an angle of θ from the vertical, what is the minimum inital velocity v0 it must have to just barely make it over the top and not oscillate?
This is what I did:
\Delta K=mgh\implies v_0=\sqrt{v^2-2gh}
but at the top, v is zero so it can be written as:
v_0=\sqrt{-2gh}
and h in this case is L+Lcosθ, so using g=-10m/s2 I get:
v_0=\sqrt{20L\left(1+\cos{\theta}\right)}
but whenever I plug in values for θ and L, I get the wrong answer. I can't see what I did wrong.
Any ideas?
Thanks a lot.
What School do you go to?
I'm in high school.
At the top the pendulum has 0 velocity (actually, it should have just a tiny non-zero velocity but you can take 0 as "boundary" between going over the top and not making it to the top) and so has no kinetic energy but has potential energy, -mgL (relative to the height of the pivot- the center of the circle the pendulum moves in). Initially, it has velocity v0 and so kinetic energy (1/2)mv0[/sub]2 AND some potential energy. Have you taken into account the fact that the potential energy has to be measured with respect to the center of the circle?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
