Calculating KE Gain with Velocity Vectors: Explained and Simplified
  • Thread starter Thread starter phospho
    Energy Vectors
The discussion clarifies the distinction between velocity and speed in the context of kinetic energy (KE) calculations. It emphasizes that KE should be calculated using the magnitude of velocity vectors, not the vectors themselves, as the formula for KE is based on scalar speed. Participants correct misconceptions about vector operations, stating that one cannot square vectors directly. The conversation also touches on the use of momentum equations, where vector forms can be utilized without needing to convert to magnitudes. Ultimately, understanding the difference between vector and scalar quantities is crucial for accurate calculations in physics.
phospho
gain in KE = 0.5mv^2 - 0.5mu^2
where v and u is velocity
say we had an object moving with velocity (i + j), and after 5m it's velocity was (2i + j), would the gain in KE be:
0.5m(2^2 + 1^2)^2 - 0.5m(1^2+1^2)^2
or
0.5(2i + j)^2m - 0.5(i+j)^2m
Just confused what to do when vectors come into play
thanks
Technically, u and v are "speed" not "velocity". That's an important distinction when you are talking about vectors: "velocity" is a vector, "speed" is the magnitude of that vector.
No. The magitude of the vector ai+ bj is \sqrt{a^2+ b^2} so the square of the magnitude is a^2+ b^2 You should have 0.5m(2^2+ 1^2)- 0.5m(1^2+ 1^2)= 0.5m(3)
or
That's wrong because you can't square vectors like that.
thanks
Neither of the formulas you give is correct. You have to work with the magnitude of the vectors. And, again, you have to distinguish between the vector velocity and the scalar speed.
Okay, so if KE is 1/2mv^2, where v is a velocity vector (this is what my book says) then why do I take the magnitude of the velocity, rather than the actual velocity vector?
Here is an actual example:
I don't particularly need help with the question but, if I was to use conservation of linear momentum on this problem:
My book says exactly this:
m_1u_1 + m_2u_2 = m_1v_1 + m_2v_2
where a body of mass m_1 moving with a velocity u_1 collides with a body of mass m_2 moving with a velocity of u_2. v_1 and v_2 are the velocities of the bodies after the collision.
Now using this concept on this problem, it would be mu + Mv = mp + Mq, however if the velocity vector was in the form of ai + bj, would it be m(ai + bj) + M(ci + dj) = m(ei + fj) + M(gi + hj) I assume. Then for energy, why do I use the magnitude of the velocity, rather than the actual velocity vector?
I hope I've made my confusion clear, thanks for helping.
Your book is using the "dot product" (also called "inner product"). If v= ai+ bj+ ck then v.v= a^2+ b^2+ c^2 which is the same as the magnitude of the vector, squared. In either case, v^2 or |v|^2 is a number not a vector.
I haven't come across that yet.
I still don't understand why I need to use the magnitude of the vector for energy, but can use the actual vector for momentum.
