Calculating Light Travel Time in Glycerine: A Homework Guide
To calculate the time it takes for light to travel 54 cm through glycerine, first determine the speed of light in glycerine using the index of refraction, which is 1.473. The formula is v = c/n, where c is the speed of light in a vacuum (approximately 2.99792 x 10^8 m/s). By substituting the values, the speed of light in glycerine is found to be about 2.03 x 10^8 m/s. Finally, to find the travel time, use the formula time = distance/speed, resulting in the time it takes for light to travel 54 cm in glycerine. This method provides a clear approach to solving the problem.
rhxoehwhfh
Determine the time it takes for light to travel 54 cm through glycerine in an aquarium.
does anybody know how make an equation for this??... because I just have no clue with this one...
You need to find the speed of light moving through glycerine. This is related to the index of refraction of glycerine. Look it up.
it is 1.473 so than is it 10 power of 8 * 1.473?
If n is the index of refraction, c is the speed of light in a vacuum and v is the velocity of light in the medium, then v=c/n.
oh so this is it right? -> 2.99792 x 10 power 8 / 1.473 = v
Yes. It would be even more right if you put units on c, like m/sec. So how long to travel 54cm?
ok thankyou verymuch sir ^^
