Calculating Magnetic Flux in a Toroidal Inductor
  • Thread starter Thread starter jhexp
    Flux Inductor
To calculate the magnetic flux through each coil of a 4.50 mH toroidal inductor with 125 coils carrying a current of 11.5 A, the formula used is φ = L * I. Initially, the user mistakenly divided the inductance by the current, resulting in an incorrect value. Upon realizing the error, the correct calculation involves multiplying the inductance (0.0045 H) by the current (11.5 A), leading to the correct magnetic flux. The final value of magnetic flux per coil is derived by dividing the total flux by the number of coils. The discussion highlights the importance of using the correct formula for calculating magnetic flux in inductors.
jhexp
A 4.50 mH toroidal inductor has 125 identical equally spaced coils.
4.5 mH = .0045 H (Wb/A)
N = 125
I = 11.5 A
φ = ? - this is what we're finding
If it carries an 11.5 A current, how much magnetic flux passes through each of its coils?
I'm really blank on this one. I know that the units for the magnetic flux, φ, will be in units Wb. My educated guess is that the equation will be φ = inductance/current.
φ = (.0045 H)/(11.5 A) = 3.91*10^-4 Wb
I divided that by 125 and got 3.13*10^-6 Wb
Likes MadelineChoate
Ah shi. How dumb of me. Just after posting I realized that I should multiply the inductance by the current and got the correct answer.
nvm, got it.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
