Calculating Mass from Acceleration and Net Force
  • Thread starter Thread starter MissFortune
To calculate the mass of the high jumper, the net force exerted by the foam pit and the jumper's acceleration must be determined using Newton's second law. The average force of -1100 N indicates the force acting against the jumper's weight. The acceleration can be calculated from the jumper's fall speed and the distance compressed in the foam pit. The correct mass is likely closer to 121 kg, as 1845 kg seems implausible given typical human weights. Proper calculations should clarify the mass based on the provided forces and distances.
MissFortune
This was the original question: A high jumper falling a 3.9 m/s, lands on a foam pit and comes to rest, compressing the pit a distance of 0.43 m. If the pit is able to exert an average fource of -1100 N on the high jumper in breaking the fall, what is the jumper's mass?
But I am not sure if I am supposed to multiply or divide 0.43m and 3.9 m/s
Ive narrowed the answer down to either 1845 kg or 121 kg.
Well, 1845kg is about 4000lbs.. whereas 121kg is about 260lbs..
Ive been leaning towards 121kg mainly because of that, but I just wanted to be sure.
Show your work and I can look over it.
Sounds like you're guessing?
(1) What's the acceleration?
(2) Apply Newton's 2nd law to find the mass. (Use the net force.)
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
