Calculating Modulus of Elasticity for a Bending Beam with Simple Equation
  • Thread starter Thread starter Iclaudius
    Beams Bending
To calculate the modulus of elasticity for a bending beam, the engineer's bending equation is applied: (M/I)*R = E. Given a radius of curvature of 300 m, a bending moment of 8 Nm, and a second moment of area of 8000 mm4, the initial calculation yields 300 Pa. However, the correct answer is 300 GPa, indicating a unit conversion error from mm4 to m4. The discussion emphasizes the importance of checking units in calculations.
Iclaudius
Hello friends,
so i have this problem:
A beam under test has a measured radius of curvature of 300 m. The bending moment applied to it is 8 Nm. The second moment of area is 8000 mm4. Calculate the modulus of elasticity for the material.
ok so using the engineers bending equation i have,
(M/I)*R = E
using the values stated above i get 300 Pa, answer however is 300 GPa - am i missing something simple? or is this a typo?
Thanks in advance
Check your units. You proably made a mistake converting mm4 into m4.
The book's answer is right.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
