Calculating Phase Shift for a Series RC Circuit
To calculate the phase shift in a series RC circuit with a resistor of 362 Ohms and a capacitor of 50.0 µF at a frequency of 11.7 Hz, the impedance is given as 452.836 Ohms. The relevant equations include the capacitive reactance (Xc = 1/(ωC)), where ω = 2πf, and the impedance formula (Z = √(R² + (Xc)²)). The phase angle is determined using the formula tan(θ) = (Xc)/R, leading to θ = tan⁻¹(Xc/R). Despite applying these equations, the calculated phase angle of 37 degrees was found to be incorrect, indicating a potential error in the calculations or assumptions made. Further review of the calculations is necessary to resolve the discrepancy.
map7s
A resistor of 362 Ohms is connected in series with a capacitor of 50.0 µF capacitance. A sinusoidal signal of f = 11.7 Hz experiences an impedance of 452.836 Ohms. Find the phase shift between the current and voltage at f = 11.7 Hz.
I tried using the equation tan = (Xc)/R
Xc=1/(wC)
w=2(pi)f
Z=sqrt(R^2+(Xc)^2)
Where are you stuck exactly?
Well, I used all four of those equations (specifically the first one b/c the question is asking for the angle), but when I plugged in my answer, it was wrong.
tan=(Xc)/R
theta=tan^-1(Xc/R)=37 degrees
Hmmm, let me read it again.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
