Calculating Power and Force in Cycling: Solving for Force in the Equation P=Fv
  • Thread starter Thread starter oisdas
    Drag Power
The discussion focuses on the relationship between power, force, and velocity in cycling, specifically using the equation P=Fv and its variations. The user attempts to connect Pave^2 to Pftp and expresses confusion about how to define force, as it includes both air resistance and the cyclist's effort. They consider the scenario of constant speed, questioning how to determine net force under this condition. Ultimately, they conclude that the force exerted by the cyclist can be equated to the air resistance when acceleration is zero, leading to the equation F = -bv^2. This highlights the complexity of calculating force in cycling dynamics.
oisdas
Professional cyclists typically travel at 40 km/h during races. Air resistance produces a force on a cyclist that obeys a law~F(v) =−bv^2 opposite the direction of motion and proportional the speed squared. The coefficient b differs from person to person. The average power Pave that a well-trained cyclist can maintain for Nh hours is roughly Pave^2= 3(Pftp^2)/Nh, where Pftp is the maximum power she can produce without lactic acid accumulation. Solve for the average speed the cyclist can maintain in terms of Pftp and the distance of the race.
P=Fv
OK, so I tried to relate the equation P=Fv to the given equation that Pave^2= 3(Pftp^2)/Nh. I put Nh in terms of distance to satisfy the requirement that the answer should be in terms of Pftp and distance by saying Nh = distance/Vave. I also substituted Pave with Fvage.
(FVage)^2 = 3(P^2ftp)Vave/d ---> Vave = 3(^2Pftp)/Fd
My problem is I don't know what to substitute force with. The force is not only the -bv^2 from air resistance, it is also the force applied by the cyclist. With this, how would I find force?
Taking the speed as constant, what is the net force?
Likes oisdas
If speed was constant, the net force would just be from air resistance. However, how would I assume that speed is constant?
Because if it varies significantly you do not have enough information.
Likes oisdas
I see, thank you! With this, I will set the force the bicyclist is applying = Fair since a=0 and get F= -bv^2.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
