Understanding Pressure Drop Calculations in Fluid Mechanics
In summary: This is a grey area between the two other types of flow.'turbulent' flow is where the flow is completely mixed between layers, and the flow is chaotic.The type of flow for this problem is very important. The answers are completely different, depending on what type of flow you have.For laminar flow, the pressure drop varies with the flow rate, according to the Hagen-Poiseuille equation.For turbulent flow, the pressure drop varies with the square of the flow rate, according to the Bernoulli equation.So, yes, calculating the Reynolds number is very important. It
kachi
Hello. I have had an attempt at solving this pressure drop problem, but I have been told it is incorrect.
I am very much a beginner in the area of fluid mechanics, so if you could please define any terms that you are using, that would be so helpful!
I thought using the Hagen-Poiseuille would fit, as the question has given data that would fit into the equation and it also suggests that the pipe is laminar (smooth pipe). Although, it does not state whether the pipe has bends or is just straight. Does 'smooth pipe' also mean 'straight pipe'? Do I assume its straight?
Why is my attempt wrong? What are the other possible ways to solve this/pressure drop?
The lecturer I asked said that this method wasn't right, and that I should just calculate pressure multiplied by all the heads (pressure x heads). I still am confused by this though.
Also, am I allowed to ask more questions relating to my given question in this thread?
The question is below:
Water at 20°C flows in a 35 cm diameter smooth pipe at a rate of 0.0476 m^3/s from the Goulburn River to the Holding tank. What is the frictional head lost* (in m) and corresponding pressure drop (in kPa) per 100m length of pipe?
EDIT: *I didn't see this part of the question...
Known data:
  • Water has a temperature of 20°C
  • Diameter of pipe is 35cm
  • Flow rate is 0.0476 m^3/s
  • Length of pipe is 100m
Hagen-Poiseuille equation:
Where:
ΔP is the pressure loss
L is the length of pipe
μ is the dynamic viscosity
Q is the volumetric flow rate
d is the diameter
Pi is the mathematical constant Pi
Using:
Where:
ΔP is the pressure loss (Pa) = ?
L is the length of pipe (m) = 100m
μ is the dynamic viscosity (Pa*s) = 1.002 for Water @ 20°C
Q is the volumetric flow rate (m^3/s) = 0.0476 m^3/s
d is the diameter (m) = 0.35m
Pi is the mathematical constant Pi Attempt:
ΔP = (128(1.002 Pa*s)(100m)(0.0476 m^3/s))/pi(0.35)^4
= 12949.786 Pa
ΔP = 12.95 kPa/100m
Pressure drop is 12.95 kPa per 100m length of pipe.
Thank you very much in advance. I appreciate it.
'Smooth pipe' does not mean 'straight pipe'. The absolute roughness of a pipe is a measure of the irregularities in the inner surface of the pipe, and different materials have different roughness values. The ratio of the roughness of the pipe material to the pipe inside diameter is an important factor in establishing how the fluid flows thru the pipe.
http://www.enggcyclopedia.com/2011/09/absolute-roughness/
I don't understand your last sentence. 'Head' is equivalent to 'pressure', just expressed in a different form. Multiplying head x pressure is meaningless.
The Hagen-Poiseuille equation is valid only if the flow in the pipe is laminar. Do you understand how to determine if the flow is laminar? Have you calculated the Reynolds number for your flow problem?
http://en.wikipedia.org/wiki/Hagen–Poiseuille_equation
To answer your original question, yes, there are other methods of calculating pressure drop, depending on whether you have laminar flow, fully turbulent flow, or something in between.
You can ask as many questions as you want pertaining to your problem, if you don't understand everything posted in the responses.
Thank you for your response. Oh ok so head is just another name for pressure. I see.No, how do I determine if a flow is laminar?
I was reading a webpage saying that laminar flow is 'smooth' and 'turbulent' flow is 'rough'. Is this description true?
http://en.wikipedia.org/wiki/Laminar_flow
In order to solve this question, is the first step to find what type of flow it has?
Do we have to calculate and obtain a value to see whether a flow is laminar or turbulent? Is this what the Reynolds equation is for?
Sorry for all the questions
The Reynolds number calculation is key to determining if your flow is laminar or not. Laminar flows have Reynolds numbers below about 2300. For circular pipe, the Reynolds No. is:
Re = v*D*ρ/μ where,
v = velocity of the flow, m/s
D = inside diameter of the pipe, m
ρ = density of the fluid, kg/m[itex]^{3}[/itex]
μ = dynamic viscosity of the fluid, Pa-s
'Laminar' flow is where the flow of the fluid occurs with no mixing between layers. As the flow increases velocity, mixing between layers will begin to occur, and the flow is said to become 'turbulent'.
Likes 1 person
Thank you very much again.
I tried the problem again earlier, it's a bit long though:
$$ N_R = V D \rho/μ$$
Where,
N_R = Reynolds number
V = Velocity of flow, 0.4947m/s
D = Diameter of pipe, 0.35m
ρ = Density of water at 20°C, 998 kg/m^3
μ = Dynamic Viscosity, 1x10^-3 Pa*s
Reynolds Number = ((0.4947 m/s)(0.35m)(998 kg/m^3))/1x10^-3 Pa*s
= 172798.7
As Reynolds number > 4000 the flow is turbulent
As the flow is turbulent, I would need to find the relative roughness of the pipe.
Relative Roughness = ε/D
Where,
ε = roughness of the 'smooth pipe', 0.0m (assuming 'smooth' is either plastic or glass)
D = diameter of pipe, 35m
Relative Roughness = 0.0m/35m
= 0.0
I have the Reynolds number (172798) and the Relative roughness (0.0).
Using the Moody diagram, I get a frictional factor of around 0.027.
Frictional Factor = 0.027
I figured out that I can't use that Hagen-Poiseuille equation as it is only for laminar flow? I learned that for the flow to be laminar the Reynolds number < 2000.
I'm using Darcy–Weisbach's equation for head loss.
$$H_L = f (L/D) (V^2/2g)$$
Where,
H_L = Head Loss
f = frictional factor, 0.027
L = Length of pipe, 100m
V = Velocity, 0.4947m/s '
g = gravity due to acceleration, 9.81m/s^2
H_L = 0.027 * (100m/0.35m) * (0.4947m/s)^2/(2*9.81 m/s^2)
= 0.0962m
Head Loss is 0.0962 metres.
To find the pressure drop can I just convert the head loss (m) to pressure drop (kPa)?
Since you said that head loss = pressure?
Head Loss --> kPa
P = SG * g * h
Where,
P = Pressure (kPa)
SG = Specific Gravity of Water at 20°C, 0.998
h = Head Loss
P = 0.998 * 9.81 m/s^2 * 0.0962m
= 0.941 kPa/100m of pipe
So the pressure drop is 0.941 kPa per 100m of pipe?
Is this right? I still can't picture these measurements in real-life to know if it's close the right answer...is the pressure and head loss too small?
Re = v*D*ρ/μ where,
Your numbers look OK to me.
Likes 1 person
Ok thank you for your help! I appreciate it.
FAQ: Understanding Pressure Drop Calculations in Fluid Mechanics
1. What is pressure drop?
Pressure drop is the difference in pressure between two points in a fluid system. It is caused by friction and other factors that act against the flow of the fluid.
2. How is pressure drop calculated?
Pressure drop is calculated using the Darcy-Weisbach equation, which takes into account factors such as fluid velocity, pipe diameter, and fluid density. Other methods, such as the Hazen-Williams equation, can also be used depending on the specific system and fluid properties.
3. What factors affect pressure drop?
Pressure drop is affected by factors such as fluid viscosity, pipe roughness, flow rate, and length of the pipe. Higher viscosity and roughness, as well as longer pipes, will result in higher pressure drop.
4. How can pressure drop be reduced?
Pressure drop can be reduced by increasing the pipe diameter, smoothing out the pipe surface, and reducing the flow rate. Additionally, using more efficient pumps or compressors can also help to reduce pressure drop.
5. Why is pressure drop important to consider?
Pressure drop is an important factor to consider in fluid systems because it affects the efficiency of the system. A higher pressure drop means that more energy is being lost, which can result in increased operating costs. It is also important to consider pressure drop in order to maintain the desired flow rate and avoid potential issues such as cavitation or pump failure.
